[GRASS5] Re: [GRASSLIST:6232] Re: gisdbase error
Markus Neteler neteler at itc.it
Fri May 9 08:32:27 EDT 2003
[moved here from grasslist]
On Fri, May 09, 2003 at 12:15:44PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> >  - graphical startup doesn't work  -> bug in Init.sh?
> >  - cmd line startup with path to GISDBASE doesn't work  -> bug in Init.sh?
> Odd. At first I thought that it might be due to the use of
> bash-specific features (Cygwin's /bin/sh is ash) but, apart from an
> unrelated bug, it works with ash on Linux.
> The unrelated bug is:
> 	trap "echo 'User break!' ; exit" 2 3 9 15
> Signal 9 is SIGKILL, which can't be caught. bash seems to ignore this,
> but it causes total failure under ash (attempting to run external
> programs fails).
Ok, I'll clean that SIGKILL everywhere. But even deleting the
line didn't help.
> Can you provide more details regarding the failures? You can get
> debugging information by using "sh -x ...", i.e.
Yes, find attached (log_wingrass.txt.gz).
Row 91 of the log is showing a problem.
Markus
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030509/1b2350e3/log_wingrass.txt.gz
