[GRASS5] v.in.dwg license problem
Glynn Clements
glynn.clements at virgin.net
Fri May 16 09:07:44 EDT 2003
Radim Blazek wrote:
> As you could see, I took your opinion into account and I have done
> some extra work for you. And I'll do some extra work every day,
> when typing 'yes' during compilations, to remind me that GPL is bad.
An interactive prompt is a bad idea; the build process shouldn't
require user interaction.
It would be better to add a --with-dwg switch to configure, and have
configure print a warning message regarding the licensing issues if
you use that switch.
Glynn Clements <glynn.clements at virgin.net>
