[GRASS5] v.in.dwg license problem
Radim Blazek
blazek at itc.it
Fri May 16 12:07:58 EDT 2003
On Friday 16 May 2003 05:26 pm, Helena Mitasova wrote:
> With all that was written by Markus and others, Bernhard do you still
> see a problem with keeping v.in.dgw in experimental GRASS5.1 in
> src.nonGPL?
I hope that it is clear that v.in.dwg code __IS__ under GPL!!!
The problem IS NOT in 'Open DWG' license, the problem is in GRASS license.
OpenDWG license allows without any fees: "You may incorporate the
OpenDWG libraries into programs that are used within your organization or school,
or are distributed for free to the general public via the Worldwide Web."
(Please read http://www.opendwg.org/membership/join.htm)
What is not possible is to distribute binaries, because GPL used for GRASS
doesn't allow it.
Open DWG license gives more freedom to distribute v.in.dwg for free than GPL.
Put it to src.nonGPL is very confusing!!!
Radim
