[GRASS5] v.in.dwg license problem
Glynn Clements
glynn.clements at virgin.net
Fri May 16 11:43:03 EDT 2003
Markus Neteler wrote:
> > > As you could see, I took your opinion into account and I have done
> > > some extra work for you. And I'll do some extra work every day,
> > > when typing 'yes' during compilations, to remind me that GPL is bad.
> > An interactive prompt is a bad idea; the build process shouldn't
> > require user interaction.
> > It would be better to add a --with-dwg switch to configure, and have
> > configure print a warning message regarding the licensing issues if
> > you use that switch.
> This is already there:
> configure --help | grep dwg
> --with-opendwg support openDWG functionality (default: no)
> --with-opendwg-includes=DIRS
> --with-opendwg-libs=DIRS
OK.
> Or did you mean something different?
No, that's what I meant.
> Only a warning had to be added if desired.
I think that would be a good idea; but the warning needs to be very
clear, e.g. surrounded by asterisks.
Glynn Clements <glynn.clements at virgin.net>
