[GRASS5] Re: [GRASSLIST:80] Re: More Solaris 9 problems - NVIZ
Glynn Clements
glynn.clements at virgin.net
Mon May 19 10:59:46 EDT 2003
Ade Fewings wrote:
> Have tried, unfortunately no different. Same errors related to .LLC16.
> Must confess to being completely lost now.
The only other difference which I can see between PJ_krovak.c and the
rest is that PJ_krovak.c lacks an SCCSID variable.
Ultimately you could just remove the Krovak projection from
src/libes/proj/Gmakefile and src/libes/proj/pj_list.h. That should
allow the rest of GRASS to be built.
Glynn Clements <glynn.clements at virgin.net>
