[GRASS5] GRASS.1: v.out.org compilation error
Moritz Lennert mlennert at club.worldonline.be
Wed May 21 11:44:01 EDT 2003
Markus Neteler said:
> On Wed, May 21, 2003 at 05:14:07PM +0200, Moritz Lennert wrote:
>> Hello,
>> Using the latest CVS versions of GRASS5.0, GRASS5.1 and GDAL, I have
>> trouble compiling GRASS5.1. I get the error message below when the
>> compilation process reaches v.out.ogr. GDAL's files are installed in
>> /usr/local/lib/ and /usr/local/include/.
>> Can someone help me with this ?
>> Moritz
>> configure command:
>> CFLAGS="-g -Wall" ./configure --with-grass50=/data/GRASSCVS/grass
>> --with-tcltk-includes=/usr/include/tcl8.3/
>> --with-postgres-includes="/usr/include/postgresql/
>> /usr/include/postgresql/internal/" --with-readline --with-dbm
>> --with-includes="/usr/include/ /usr/local/include/"
>> --with-libs="/usr/lib/
>> /usr/local/lib"
>> make output:
>> v.out.ogr
>> make[2]: Entering directory `/data/GRASSCVS/grass51/vector/v.out.ogr'
>> gcc -I/usr/include/ -I/usr/local/include/ -g -Wall  -Wall
>> -I/usr/include/
>> -I/usr/local/include/ -I/data/GRASSCVS/grass51/include
>> -I/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/include
>> -I/usr/include/postgresql/ -I/usr/include/postgresql/internal/
>> -I/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/include \
>>         -o OBJ.i686-pc-linux-gnu/main.o -c main.c
>> /data/GRASSCVS/grass51/include/gis.h:36: warning: `GRASS_copyright'
>> defined but not used
>> gcc -L/usr/lib/ -L/usr/local/lib
>> -L/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib  -L/usr/lib/
>> -L/usr/local/lib  -o
>> /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/etc/bin/cmd/v.out.ogr
>> in.o /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_vect.a
>> /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dig2.a
>> /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_shape.a  -lpq
>>   /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_btree.a
>> /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_rtree.a
>> /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_linkm.a
>> /data
>> /GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dbmi.a
>> /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dbmi.a
>> /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_gis.a    -ldl
>> -lm  -lz
>> OBJ.i686-pc-linux-gnu/main.o(.text+0x296): In function `main':
>> /data/GRASSCVS/grass51/vector/v.out.ogr/main.c:145: référence indéfinie
>> vers « OGRRegisterAll »
> Above -lgdal.1.1 is missing. What does
> cd grass51src/
> grep GDALLIBS include/Make/Platform.make
> say?
GDALLIBS            = -ldl
