On Thu, 22 May 2003, Glynn Clements wrote: > Check which version of "wish" is actually being used; Tcl 8.2 should > understand that command. Yes, that was the problem: an old version of wish in /usr/bin was being used. I set the GRASS_WISH environment variable to the wish8.2 and it works now, thank you Paul
