[GRASS5] GRASS5.1: trouble importing shape file with v.in.ogr
Moritz Lennert mlennert at club.worldonline.be
Tue May 27 10:33:19 EDT 2003
Hello,
I'm trying to import a shapefile into GRASS5.1 using v.in.ogr. I get the
following message when trying to import:
v.in.ogr dsn=/home/mlennert out=cp_in layer=cp
dbmi: Protocol error
ERROR: Cannot create table: create table cp_in (cat integer, CP_ID integer,
       PC4_CODE varchar ( 4 ), PC4_NAME varchar ( 40 ), LANG1 varchar ( 3 ),
       PC4_NAME2 varchar ( 40 ), LANG2 varchar ( 3 ), X integer, Y integer,
       SUPERFICIE integer, Z1_81_100 integer, DENSITé97 integer, POP97_81
integer,
       BEST_SCORE integer, BEST_SCORE integer, PART_DE_ME double precision,
       PART_DES_M double precision, BOITES_à_C integer, PART1 integer)
I can import the file with v.format.
Moritz
