[GRASS5] compile problem...
Moritz Lennert
mlennert at club.worldonline.be
Tue May 27 14:41:34 EDT 2003
Yann said:
> Hello,
> I had a complete cvs built made few days back, and grass51 was working
> from it... now it is making some trouble around libpq-fe.h, any idea,
> suggestion please.
> Thank you
> Yann
> Mandrake 9.1, postgres, postgis, gdal, ogr, proj, freetype (all built
> from source except freetype)
> fresh cvs of Grass5.0 (cvs up -dP grass)
> Grass built cleanly except for some non-critical g3d error
> cvs up -dP grass51
> make clean
> Config command => ./configure --with-grass50=/home/yann/grass
> --with-postgres-includes=/usr/local/pgsql/include --with-gdal
> --with-proj --with-ogr --with-postgrass --with-postgis
> --with-freetype-includes=/usr/include/freetype2
> make mix
> make result in:
> make[2]: Entering directory `/home/yann/grass51/display/d.extract'
> gcc -g -O2 -Wall -I/home/yann/grass51/include
> -I/home/yann/grass51/dist.i686-pc-linux-gnu/include
> -I/home/yann/grass51/dist.i686-pc-linux-gnu/include \
> -o OBJ.i686-pc-linux-gnu/extract.o -c extract.c
> In file included from /home/yann/grass51/include/vect/digit.h:3,
> from /home/yann/grass51/include/Vect.h:4,
> from extract.c:8:
> /home/yann/grass51/include/vect/dig_structs.h:22:22: libpq-fe.h: No such
> file or directory
Maybe a dumb question, but where is libpq-fe.h on your machine ?
Moritz
