[GRASS5] Grass 5.3 on Mac OSX
Glynn Clements glynn.clements at virgin.net
Tue Nov 11 17:35:29 EST 2003
Michael Barton wrote:
> On the other hand, I could simply create a tarball of the
> user/local/grass5 directory and /user/local/bin grass files (grass5,
> gmake5 and gmakelink5 I think), gzip them and send them to someone if
> they want them. Are there any other files  I need to include?
gmake5 and gmakelinks5 are of no use without the source code; there is
little point in including them in a binary distribution.
> Question: After the fact can I change the name of /usr/local/bin/grass5
> to /usr/local/bin/grass53?
Yes.
> Same for gmake5 and gmakelink5 files,
Yes, but probably not relevant; see above.
> and /usr/local/grass5 directory?
Yes, but:
1. You need to change the value of GISBASE in the grass5 script.
2. gmake5/gmakelinks5 won't work correctly; they will use the original
paths which are embedded into Makefile and src/CMD/head/head.<arch> by
the configure script. But, again, probably not relevant; see above.
Glynn Clements <glynn.clements at virgin.net>
