New PNG driver - was: Re: [GRASS5] Re: [GRASSLIST:1560] Re: back ground
Markus Neteler neteler at itc.it
Wed Nov 12 05:06:33 EST 2003
> > I'll re-write PNGdriver not to use GD; that will have the added
> > benefit of eliminating all GD dependency issues.
> Done.
> Testing would be appreciated. I'm particularly interested in comments
> regarding both the behaviour and performance of filled polygons.
> Glynn Clements <glynn.clements at virgin.net>
The new PNG driver seems to work fine in 5.7. I have made
the relevant updates in the configure[.in] and the Makefile
(commented GD lib stuff). Someone should do the same for
5.3 configure[.in] and REQUIREMENTS.html.
Markus
