[GRASS5] SEARCH_PATH
Thierry Laronde tlaronde at polynum.com
Fri Nov 14 10:13:40 EST 2003
On Fri, Nov 14, 2003 at 01:49:55AM +0000, Glynn Clements wrote:
> > Users need only to set some symbolic links (on OSes supporting this) in
> > the location pointing to other repositories and list them in
> > SEARCH_PATH.
> Well, ideally the user shouldn't have to be fiddling around with the
> internals of the database directory or making symlinks.
Hamish wrote:
> Do you mean:
> d.rast rastmap at othermapset
Well, you can put additionnal mapsets, via g.mapsets, but you can also
create under your location (directory) symbolic links pointing to, for
example, a nfs mounted tree, and add this symbolic link name to the file
SEARCH_PATH (or via g.mapsets) meaning that one is not restricted to her
own LOCATION or to the inside of the GRASS database.
Yes, as Glynn says this _can_ be messy if people do this without knowing
exactly what they do, but this is a mean, not more dirty than others if
used with reflexion, to indeed "escape" GRASS database in order to
access "remote" data.
One can also use it (but I would not emphasize the possibility in the
user's manual, but only in the admin's one) to see some MAPSETS of
other LOCATIONS (for example to display a vector/raster overlay).
Thierry Laronde (Alceste) <tlaronde at polynum.org>
Key fingerprint = 0FF7 E906 FBAF FE95 FD89  250D 52B1 AE95 6006 F40C
