[GRASS5] binaries for 5.0.3 - 1 for testing (Linux), 2 (Sun,Mac)
problems
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Nov 14 11:39:11 EST 2003
On Fri, 14 Nov 2003, Scott W Mitchell wrote:
> Meanwhile, IF it should be pursued, I'm getting undefined symbols
> on an OS X system as well, in about a dozen modules. Here's an example,
> does it ring a bell or tell us anything ?
Use 5.3, where the internal proj library has been renamed from libproj to
libgproj, or uninstall your external copy of proj. This is to do with the
search order of libraries under OS X and the way it is sometimes
ignored (shared libraries always used in preference to static with the
same name). Shouldn't be pursued, I would say, as it is already fixed.
> /Users/smitch/src/grass-5.0.3/src/general/g.region/cmd
> make -f OBJ.powerpc-apple-darwin6.8.5/make.rules
> gcc
> -L/Users/smitch/src/grass-5.0.3/src/libes/LIB.powerpc-apple-darwin6.8.5 -s
> -L/sw/lib -o
> /Users/smitch/src/grass-5.0.3/dist.powerpc-apple-darwin6.8.5/etc/bin/cmd/g.region
> OBJ.powerpc-apple-darwin6.8.5/printwindow.o
> OBJ.powerpc-apple-darwin6.8.5/adjust.o
> OBJ.powerpc-apple-darwin6.8.5/main.o OBJ.powerpc-apple-darwin6.8.5/zoom.o
> -lvect -ldig2 -lgis -lintl -ldatetime -lproj -lz
> ld: Undefined symbols:
> _pj_do_proj
> _pj_get_kv
> _pj_zero_proj
> make[1]: ***
> [/Users/smitch/src/grass-5.0.3/dist.powerpc-apple-darwin6.8.5/etc/bin/cmd/g.region]
> Error 1
> make: *** [all] Error 1
> Thanks,
> Scott
> Scott W. Mitchell
> Department of Geography and Environmental Studies
> Carleton University, B349 Loeb Building (Office A209)
> 1125 Colonel By Drive, Ottawa, ON Canada K1S 5B6
> +1-613-520-2600 ext 2695 Fax: 1-613-520-4301
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
