[GRASS5] v.in.dxf attribute question
Michael Barton michael.barton at asu.edu
Sun Nov 16 15:29:15 EST 2003
Is this why it will NOT read a MapInfo file I export  to DXF with
attributes and WILL read a MapInfo file exported to DXF without
attributes?
Michael Barton
> Subject: v.in.dxf not converting 8bit TEXT
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> DXF has a convention for encoding 8bit strings in 7bit strings by
> using a
> decimal representation ('%%ddd') for bytes with 8th bit set. Example:
>   0
> TEXT
>   8
> TOPOGRAPHIE
>  62
> 7
>  10
> 3453700.036000
>  20
> 5556212.001000
>  30
> 0.000000
>  40
> 3.200000
>  41
> 1.200000
>   1
> Kantstra%%223e
>   7
> ISO8
>  50
> 43.988400000000
>  51
> 16.700000000000
> v.in.dxf does not convert the 7bit encoding to 8bit.
> I have made the following patch to src/mapdev/v.in.dxf/label_box.c to
> solve
> the problem for myself:
> *** label_box.c.orig    Tue Jan 22 05:51:14 2002
> --- label_box.c Sun Nov 16 10:58:00 2003
> *** 31,36 ****
> --- 31,37 ----
>         DXF_DIG *layer_fd, *label_fd;
>         int     count, char_cnt, code;
>         char    label[256];                     /* same size as
> dxf_line */
> +         char    text_style[256];
>         double  start_x, start_y, angle, theta, height, length, diag;
>         double base1, base2;
>         int arr_size = 0;
> *** 42,47 ****
> --- 43,49 ----
>         start_y = 0.0;
>         height = 1.0;
>         angle = 0.0;
> +         text_style[0] = '\0';
>         while ((code = dxf_readcode (dxf_file)) > 0)
> *** 73,78 ****
> --- 75,83 ----
>                 case 50:        /* Text angle */
>                     angle = atof (dxf_line);
>                     break;
> +               case  7:        /* Text Style */
> +                     strcpy(text_style,dxf_line);
> +                     break;
>                 case 30:        /* Z */
>                 case 41:        /* relative X scale factor */
> *** 86,92 ****
>                 debugf("TEXT got unused code %d\n", code );
>                 case 62:        /* Color */
> -               case  7:        /* Text Style */
>                 case  6:        /* Line type */
>                 default:
>                     break;
> --- 91,96 ----
> *** 181,186 ****
> --- 185,195 ----
>         ** fprintf (label_fd->fd, "L  %lf %lf
> %d\n",pt_array[2].x,pt_array[2].y,label);
>         ** Labels now characters, not integers  BCH-J
> +     if (strcmp(text_style,"ISO8") == 0) {
> +       iso8_convert(label);
>       fprintf (label_fd->fd, "L  %f %f %s\n",xinfo[0],yinfo[0],label);
>       return (0);
> *** 212,214 ****
> --- 221,252 ----
>       return (-1);      /* NOT NUMERIC */
> + int iso8_convert(char *s) {
> +   char *sub;
> +   if (s == NULL) return(-1);
> +   while  ((sub = strstr(s, "%%")) != NULL) {
> +     int sublen = strlen(sub);
> +     if (sublen < 5) break;
> +     if (isdigit(sub[2]) && isdigit(sub[3]) && isdigit(sub[4])) {
> +       char dec[4];
> +       int c, i;
> +       strncpy(dec, &(sub[2]), 3);
> +       dec[3] = '\0';
> +       c = atoi(dec);
> +       sub[0] = c;
> +       i = 5;
> +       while (sub[i] != '\0') {
> +         sub[i-4] = sub[i];
> +         i++;
> +       sub[i-4] = '\0';
> +     s = &(sub[1]);
> +   return(0);
> Best regards,
> Michael Sczittnick
> -------------------------------------------- Managed by Request Tracker
> From: Michael Barton <michael.barton at asu.edu>
> Date: Sun Nov 16, 2003  12:54:15 PM Europe/Madrid
> To: grass5 at grass.itc.it
> Subject: [GRASS5] i.points and i.rectify question
> In versions 5.0.x and 5.3 are the 2 modules i.points and i.points3.
> The documentation for both versions of GRASS discuss the associated
> programs i.rectify and i.rectify3. However, there does not seem to be
> a module i.rectify3 anywhere. Some months back, before I realized that
> i.rectify3 was missing, I tried both i.points and i.points3 and found
> i.points3 to be a better program in several respects. However, the
> output file it creates (image xy and georeferenced coordinate pairs)
> seems to be ONLY in lat long and does not work with i.rectify. This
> was a major headache.
> Has anyone else run into this? Is there any way to "rectify" this
> problem? ;-)
> ____________________
> C. Michael Barton, Professor
> Department of Anthropology
> PO Box 872402
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> From: Thierry Laronde <tlaronde at polynum.com>
> Date: Sun Nov 16, 2003  3:05:36 PM Europe/Madrid
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass5 at grass.itc.it
> Subject: Re: [GRASS5] i.points and i.rectify question
> Hello,
>> The
>> a
>> was
>> a major headache.
>> problem? ;-)
> Since I'm wandering in the historical 4.1.5 release, I gave a look at
> these.
> Indeed, there were (back to 4.1.5) i.rectify in src and i.rectify2 in
> src.alpha. In 5.[03] there were a merge between i.rectify and
> i.rectify2
> but it seems that there were some clash: i.rectify2 was due to be
> renamed i.rectify, but remained i.rectify2 and there is another
> i.rectify3 (with some fixes).
> So i.rectify2 and i.rectify3 are in the sources but only a i.rectify is
> present in the binaries, which seems to be i.rectify2 since i.rectify3
> is not compiled by default.
> For i.points, there were in src: i.points, in src.alpha: i.vpoints and
> the resulting i.points3  seem to be a merge between i.points and
> i.vpoints. And there is no i.points2
> Yes, my head spins too...;)
> Thierry Laronde (Alceste) <tlaronde at polynum.org>
> Key fingerprint = 0FF7 E906 FBAF FE95 FD89  250D 52B1 AE95 6006 F40C
> Date: Sun Nov 16, 2003  7:35:07 PM Europe/Madrid
> To: grass5 developers list <grass5 at grass.itc.it>
> Subject: [GRASS5] Duplicates: some stats
> Hello,
> I have made a pass to detect C files (whether .c or .h) which are
> equals to a particular percentage (i.e. they differ (in lines) for less
> than a particular threshold, for less than a particular percentage of
> their number of lines).
> Here the pass has been made asking for a 95% equality (in other words
> for files differing in less than 5% of their lines).
> This results in 1622 duplicates.
> I attach the resulting file, which reports the pair of files compared.
> Interestingly, you will see that some files in src AND in src.nonGPL
> are
> equals...
> <grass50.duplicates.gz>
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
