[GRASS5] [bug #1759] (grass) d.what.sites: very slow over a network connection
Harmisch Bowman via RT
grass-bugs at intevation.de
Mon Nov 17 02:04:09 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1759
Request number 1759 was commented on by 'hbowman' (Harmisch Bowman).
Responding to this message will send mail to the requestor.
Request Tracker
rt at intevation.de
Cc: grass5 at grass.itc.it
GRASS 5.3/HEAD (Nov 2003)
Using the non-5.0.x d.what.sites over a 10Mbit ssh connection down the hall is
very slow & uses a ton of bandwidth during the "vector blink" stage. The
cursor doesn't return to crosshairs for several seconds, to the point where it
is unusable. (sites file contains a total of 4 sites)
see also:
http://article.gmane.org/gmane.comp.gis.grass.devel/1380
blame:
R_panel_save() & R_panel_restore() sending xwd over the X connection, followed
by a disk write to a temporary file.
but what can be done to fix the problem? The current situation sucks.
Would Carl Worth's driver fix this? Figure out how not to use XGetImage() and
XPutImage()?
'd.barscale -m' seems to work ok without such issues..?
[also, cosmetically, I'd think you'd want a -v:verbose flag not a -q:quiet
flag to show / suppress debug info. And the -q flag should suppress the
"loading sites at mapset...NDIM=2, RTYPE = 0, NSTR=5, NDEC=0"
text as well.. I can make the change if people agree, or not if they don't.
noisiest wins.]
Hamish
-------------------------------------------- Managed by Request Tracker
