[GRASS5] strange tk.h problem
moovida_lists moovida at katamail.com
Thu Nov 20 07:17:10 EST 2003
You are absolutely right.
The config.log was of help.
Thanks & cheers
Andrea
On Thursday 20 November 2003 12:40, Glynn Clements wrote:
> moovida_lists wrote:
> > I got a real strange tk.h problem I never had before.
> > I run
> > ./configure --prefix=/home/moovida/grass/the_grass/
> > --bindir=/home/moovida/ grass/bin/
> > --with-postgres-includes="/usr/include/pgsql/ /usr/include/pgsql/
> > server/" --with-motif --with-motif-includes=/usr/X11R6/include/
> > --with-gdal=/ usr/local/bin/gdal-config
> > and at the point of tcl/tk the following happens:
> > checking for location of Tcl/Tk includes...
> > checking for tcl.h... yes
> > checking for tk.h... no
> > and it stops.
> > Considering that tk.h is in /usr/include/ just like tcl.h is, I'm a bit
> > lost in space. It is just a check if the file exists, so I controlled
> > permissions, owner and whatever regarding to file integrity.
> > Did anyone ever encounter this problem?
> Header checks don't simply check that the file exists; they attempt to
> preprocess a test program which consists of a #include statement for
> the header in question (in this case "#include <tk.h>"); if the
> preprocessor produces any error/warning messages, the check fails.
> tk.h depends upon the X headers, as well as tcl.h. So if there are any
> problems with the X headers, the check will fail. Note that "problems"
> includes anything that results in a warning, not just errors.
> Examine config.log for any clues.
____________________________________________________________________________
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel:  +393288497722
fax:  +390461882672
