[GRASS5] s.in.dbf
    Thierry Laronde
    tlaronde at polynum.com
    Thu Nov 20 10:50:50 EST 2003
Hello Michael,
On Wed, Nov 19, 2003 at 11:10:32PM +0100, Michael Barton wrote:
> Last Spring, when I was doing a lot of testing, trying to bring my
> archaeological research data into GRASS, I ran into a problem with
> s.in.dbf. Basically, it didn't work right. Sometimes it wouldn't import
> anything and other  times it would import the site points (i.e., xy
> coordinates) and text fields, but remaining fields would go to 0.
I have hit some bugs with the `PostgreSQL' flavor of the DBF support.
Having a quick glance at the source, many problems lie in the file
dump.c (the `init' bug I have fixed in pg.in.dbf, no dynamic allocation
of data (leading to a buffer overflow) etc.).
As emphasize some weeks ago, there are thousands of duplicates/clones so
it's useless to fix something in some place, since the bugs will remain
elsewhere...
Solution:
May I suggest to dump in ASCII using the fixed version (in 5.O HEAD aka
5.3) of pg.in.dbf, format the file with some awk black magic, and
reimport using s.in.ascii ?
The new version of pg.in.dbf let you specify (in admin mode) the
separator, making it relatively easy to treat the result with awk or
some other fields processor.
Cheers,
Thierry Laronde (Alceste) <tlaronde at polynum.org>
Key fingerprint = 0FF7 E906 FBAF FE95 FD89  250D 52B1 AE95 6006 F40C
