[GRASS5] Re: [GRASSLIST:1899] ERROR in read/write portable short
Christopher Fonnesbeck
chris at fonnesbeck.org
Fri Nov 28 13:04:44 EST 2003
On Nov 27, 2003, at 9:13 AM, Radim Blazek wrote:
> On Wednesday 26 November 2003 20:38, you wrote:
>> I think I have everything configured properly for an OSX build,
>> however, I get the following errors. Any ideas? I scanned the list
>> archives, but did not find anything helpful:
>> cd OBJ.powerpc-apple-darwin7.0.0;
>> LD_LIBRARY_PATH=:/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-
>> apple-darwin7.0.0/lib ./test
>> Written: -32768
>> Read : 0
>> Written: -12345
>> Read : -57
>> Written: 12345
>> Read : 57
>> Written: 32767
>> Read : -1
>> make[3]: *** [OBJ.powerpc-apple-darwin7.0.0/test] Error 1
>> make[2]: *** [subdirs] Error 1
>> make[1]: *** [subdirs] Error 1
>> make: *** [default] Error 1
> I read in the list, that LD_LIBRARY_PATH does not work on MacOSX,
> and DYLD_LIBRARY_PATH should be used instead. Did you set
> DYLD_LIBRARY_PATH to
> /usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/
> lib
> before somehow? Otherwise it should not work.
> Do you have 5.7 only? Are you sure that 5.0 libraries are not
> used (are not in DYLD_LIBRARY_PATH) instead of 5.7 libraries?
I tried setting DYLD_LIBRARY_PATH, with the same resulting error. I've
never had to set this variable building other programs on OSX.
> Try also
> ldd
> /usr/local/src/grass57_exp_2003_11_22/lib/vector/diglib/OBJ.powerpc-
> On little endian
> dec hex
> -32768 = 00 80
> -12345 = C7 CF
> 12345 = 39 30
> 32767 = FF 7F
> dec hex
> 0 = 00
> -57 = FF C7
> 57 = 39
> -1 = FF FF
> So it seems that 2. byte is lost.
> This will be a bug in diglib, it was developed on intel and probably
> never run on Power PC.
> I updated grass51/lib/vector/diglib/test.c so that it prints byte
> order also,
> please update from cvs or download from web
> http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass51/lib/vector/
> diglib/test.c?rev=1.7&content-type=text/plain
> then recompile diglib and send us your new error report (should
> include " ... byte_order = ... "),
> include/portable.h and
> usr/local/src/grass57_exp_2003_11_22/lib/vector/diglib/test.tmp
> (gzipped)
Here is the error now:
ERROR in read/write portable short, byte_order = 0
Written: -32768
Read : 0
Written: -12345
Read : -57
Written: 12345
Read : 57
Written: 32767
Read : -1
See requested files attached.
Thanks for the help.
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20031128/5bcac575/osx_compile.tar.gz
> By chance, anybody knows how long type 'short' is on Power PC, and
> which endian.
> Paul, you have 5.7 compiled on some non intel platforms, can you send
> us your
> portable.h files for those machines also?
> Radim
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
