[GRASS5] errors v.digit in G57
Stephan Holl sholl at gmx.net
Sun Oct 5 05:47:15 EDT 2003
Dear developers,
v.digit in G57 does not work. Backtracing with gdb gives the following
results.
How can I compile G57 with better debug-output?
I did not perform a "make install" because I run it out of the
source-tree/dist.$ARCH/-directory.
can anybody provide help, please?
This GDB was configured as "i386-linux"...
(gdb) run
Starting program:
/home/steph/cvs/grass51-cvs/dist.i686-pc-linux-gnu/bin/v.digit
Program received signal SIGTRAP, Trace/breakpoint trap.
0x40000b00 in _start () from /lib/ld-linux.so.2
(gdb) bt full
#0  0x40000b00 in _start () from /lib/ld-linux.so.2
No symbol table info available.
(gdb)
cheers
	Stephan
Stephan Holl
GnuPG Key-ID: 11946A09
 11:43:19 up  1:01,  1 user,  load average: 0.04, 0.11, 0.14
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20031005/2e319966/attachment.bin
