[GRASS5] Re: [GRASSLIST:1363] Re: compiling grass57
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Oct 7 06:50:40 EDT 2003
On Fri, 26 Sep 2003, Paul Kelly wrote:
> On Sat, 27 Sep 2003, Hamish wrote:
> > Is it a good idea to have the 5.7 'make mix' command check
> > src/CMD/VERSION for 5.3* ? That would stop some of the questions.
> Probably better for the configure script to check, and it could check for
> 'cvs' in the version number which should be more robust for the long term.
> The following patch to configure.in seems to work:
> --- configure.in.orig Fri Sep 26 16:11:46 2003
> +++ configure.in Fri Sep 26 16:26:02 2003
> @@ -35,8 +35,11 @@
> if test -d "$with_grass50"; then
> GRASS50="$with_grass50"
> + if ! grep cvs "${GRASS50}/src/CMD/VERSION" >/dev/null 2>&1 ; then
> + AC_MSG_ERROR([*** GRASS 5.3 source directory \"$with_grass50\" does not contain CVS HEAD version.])
> + fi
> else
> - AC_MSG_ERROR([*** GRASS 5.0 source directory \"$with_grass50\" does not exist.])
> + AC_MSG_ERROR([*** GRASS 5.3 source directory \"$with_grass50\" does not exist.])
> fi
> AC_SUBST(GRASS50)
> There seems to be a problem with CVS access from inside my University at
> the minute (looks like another new firewall rule) so I can't commit the
> change right now.
My CVS access is working again now so I have committed a similar fix to
the 5.7 configure script.
Paul
