[GRASS5] Licensing problem
    Bernhard Reiter
    bernhard at intevation.de
    Wed Oct  8 09:46:48 EDT 2003
On Wed, Oct 08, 2003 at 01:41:15AM +0200, Bernhard Reiter wrote:
> On Thu, Sep 25, 2003 at 05:45:31PM +0200, Bernhard Reiter wrote:
> > > > We need to:
> > > > 	a) replace ./src/include/color.h
> > > Method 3:
> > > Delete src/include/color.h and replace its sole use in
> > > src/ps.map/ps.map/cmd/vector.h with a local definition for the only
> > > portion which is actually used:
> > > 	typedef	struct {
> > > 		unsigned short r, g, b;
> > > 	} RGB;
> > Sound good to me if "color.h" is not included somewhere else.
> > Can you make the change Method 3 then?
> I've done the change for releasebranch_26_april_2002_5_0_0 now.
Also done for HEAD now, Markus promised to do a build test.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20031008/d240f389/attachment.bin
