[GRASS5] GRASS 5.0.3 release candidate 4 (RC4) available
Glynn Clements glynn.clements at virgin.net
Thu Oct 9 09:01:06 EDT 2003
Markus Neteler wrote:
> > * Unfortunately src.nonGPL got partly packaged,
> >   this needs to be removed from the tarball.
> Strange:
> cat src.nonGPL/CVS/Tag
> Treleasebranch_26_april_2002_5_0_0
> Why is that tagged? Did you tag it (please remove then)?
> I have just updated the tree.
src.nonGPL wasn't removed until after the release branch was created
(AFAICT, it was removed the following day).
Did you use "cvs update -dP"? Empty directories will only be removed
if you use the "-P" switch. Similarly, directories which exist in the
repository but not in your local copy will only be added if you use
the "-d" switch.
If you checked out a copy of the release branch on the day it was
created, then updated it without "-P" (or if you made a copy of the
head then updated it to the release branch without "-P"), the
src.nonGPL directory (and its subdirectories) will still exist (with
the appropriate tag), they just won't contain any files.
Personally, I have "update -dP" in my ~/.cvsrc file, so "cvs update"
will always add and remove directories as necessary.
Glynn Clements <glynn.clements at virgin.net>
