[GRASS5] [bug #2152] (grass) VRML 1.0 export
Glynn Clements
glynn.clements at virgin.net
Sun Oct 12 14:41:52 EDT 2003
Paul Kelly wrote:
> > The VRML 1.0 export is not working well. The mesh producted is not standard VRML. It
> > adds a ' , ' after the last Coordinate3 point description. Same for the last
> > IndexedFaceSet : should be "a,b,c,-1" and not "a,b,c,-1,"
> The attached patch to p.vrml would fix this (presumably the Material Color
> section should have the same treatment). But I haven't had any problems
> with the current output. Are there some readers the VRML output won't work
> with? Can you give a link to somewhere describing the VRML standard that
> shows it as you describe? Then we could apply the change to p.vrmlIndex: put_grid.c
The VRML 1.0 standard explicitly permits a trailing comma:
http://www.web3d.org/technicalinfo/specifications/VRML1.0/index.html#Fields
Multiple-valued fields are written as a series of values
separated by commas, all enclosed in square brackets. If the
field has zero values then only the square brackets ("[]") are
written. THE LAST MAY OPTIONALLY BE FOLLOWED BY A COMMA. If
the field has exactly one value, the brackets may be omitted
and just the value written. For example, all of the following
are valid for a multiple-valued field containing the single
integer value 1:
[Emphasis mine.]
So, it's a bug in the viewer.
FWIW, VRML 97 is even more liberal; the comma is considered a
whitespace character.
Glynn Clements <glynn.clements at virgin.net>
