[GRASS5] [bug #2178] (grass) r.bilinear writes 0 instead of NULL
Glynn Clements glynn.clements at virgin.net
Wed Oct 22 07:27:34 EDT 2003
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2178
> Subject: r.bilinear writes 0 instead of NULL
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> BUG
> r.bilinear write 0 instead of NULL:
> GRASS:~ > r.info -r elev.bilin
> min=0.000000
> max=1432.306152
> GRASS:~ > r.null elev.bilin setnull=0
> Writing new data for [elev.bilin]...  100%
> min=1136.674438
> max=1432.306152
> This happens at the west/north result map borders where 0 instead of NULL
> is written.
It should only be East/West. The North/South check writes NULLs.
I've committed a fix; this should probably go into 5.0.3.
Glynn Clements <glynn.clements at virgin.net>
