[GRASS5] G3D-api error
N.J. Hardebol
harj at geo.vu.nl
Tue Sep 2 09:52:42 EDT 2003
Hello,
I'm writing a geophysical routine and I'd like to store a 3D temperature
field as G3D raster.
In the past I encountered some problems to find all the includes and lib -
this is properly solved.
I'm using Grass5.0.2 under Suse Linux 8.2
but,
I'm not succeeding in writing my data to a g3d file.
I'm using the following functions (and some more..):
G3d_openCellNew (char *name, int type, int cache, G3D_Region *region); that
returns a void* which is a pointer to the newly created g3d-raster - Am I
right?
G3d_putValue (void *map, int x, int y, int z, char *value, int type); where
void *map revers to the opened g3d-raster
my g++ compiler tells me that *map should be of type G3D_Map instead of
void*.
checking the grass5.0.2/src/include/G3d.h confirms this with the following
function declaration:
int G3d_putValue(G3D_Map *, int, int, int, char *, int);
What am I doing wrong? - Or do some inconsistencies exist in the g3d-api?
with kindest regards,
Nico
