[GRASS5] color table
Glynn Clements
glynn.clements at virgin.net
Thu Sep 4 17:04:54 EDT 2003
Markus Neteler wrote:
> > > If possible, I would like to release 5.0.3 tomorrow or
> > > Thursday latest (then I am out of town for more than a week).
> > I'd like more time to look at the changes. Note that nobody has posted
> > a comprehensive summary of what's actually changed. I'm fairly sure
> > that some of those changes don't belong in the release branch (e.g.
> > Mike's MinGW stuff in src/general/init/chk_dbase.c, possibly
> > elsewhere).
> No problem to wait. I would appreciate if the changes get reviewed.
A few more issues:
1. src/tcltkgrass/module/d.grid has been updated for the bordercolor=
option and -b/-g flags, but these aren't in the release version of
d.grid itself. Which one is wrong?
2. The src/tcltkgrass/module/r.proj update introduced a typo:
{checkbox -n {Do not preform region cropping optimization} "" -n}
I've fixed this one in both head and release branch.
3. The signal handling changes in
src/general/init/grass.src
src/general/init/init.sh
prevent trapping SIGKILL (9) and SIGTERM (15). Not trapping SIGKILL is
sensible enough (IIRC, this will fail on some shells), but why avoid
trapping SIGTERM?
4. Some of the changes seem rather extensive for something that's
supposed to be a bug-fix release. Specifically: d.barscale, v.in.dgn,
m.in.e00, r.los, r.spread.
I've attached a summary of the changes.
Glynn Clements <glynn.clements at virgin.net>
aclocal.m4
LOC_CHECK_VERSION
src.contrib/GMSL/NVIZ2.2/src/interface.h
Tk 8.4 fix
src.garden/grass.postgresql/g.column.pg/main.c
src.garden/grass.postgresql/g.stats.pg/infxStats.c
Newlines in string literal
src.garden/grass.postgresql/g.select.pg/main.c
Unset PG_HOST if no host specified
src/CMD/VERSION
5.0.2 -> 5.0.3
src/CMD/lists/GRASS
Add src/general/g.parser
src/display/d.area/screenpoly.h
Wrap uint8_t/uint32_t definitions in #if !defined ( __CYGWIN32__ )
src/display/d.barscale/cmd/draw_scale.c
src/display/d.barscale/cmd/main.c
src/display/d.barscale/cmd/mouse.c
src/display/d.barscale/cmd/options.h
src/tcltkgrass/module/d.barscale
Upgrade
src/display/d.geodesic/cmd/Gmakefile
Remove gratuitous $(MATHLIB) from LIBES, DEPLIBS
src/display/d.leg.thin/main.c
Force boxes to be at least 1 pixel wide/high
src/display/d.what.sites/main.c
Change help text
src/display/devices/PNGdriver/Gmakefile
Add $(MATHLIB)
src/display/devices/windows/libW11/w32/xlib.c
Fix XCreateImage
src/fonts/fonts/cyrilc.hmp
src/fonts/for_grass/splitfont.c
char -> int (workaround for gcc internal error)
Allow wider character sets
src/general/g.ask/cmd/main.c
src/general/g.filename/cmd/main.c
src/general/g.findfile/cmd/main.c
include <string.h>, <stdlib.h>
src/general/g.gisenv/main.c
Don't use G_gisinit(); tolerate invalid environment
src/general/g.mapsets/main_cmd.c
Fix help text
src/general/g.parser/test.sh
Enhance example script
Don't trap SIGKILL, SIGTERM
Add version number
Fix for first-time use
Change test -e -> test -r
src/general/init/mke_loc.c
src/general/init/mke_mapset.c
src/general/init/set_data.c
Quote paths in system() argument
-src/imagery/i.class/draw_match.c
Remove draw_match.c
src/imagery/i.ortho.photo/libes/Gmakefile
Tidy
src/libes/gis/sleep.c
Don't retrive timezone
-src/libes/proj/doc/OF90-284.pdf
-src/libes/proj/doc/PROJ.4.3.I2.pdf
-src/libes/proj/doc/PROJ.4.3.pdf
-src/libes/proj/doc/SWISS.pdf
Removed
src/libes/proj/do_proj_nad.c
src/mapdev/v.build/main.c
Indent messages
src/mapdev/v.digit/node_lines.c
Use LEFTB/RIGHTB/MIDDLEB macros
src/mapdev/v.digit/set_thresh.c
Display map scale
Tidy
src/mapdev/v.in.dgn/Gmakefile
src/mapdev/v.in.dgn/README
src/mapdev/v.in.dgn/main.c
src/mapdev/v.in.mif/main.c
src/mapdev/v.in.mif/write_lines.c
Use sprintf() instead of snprintf()
src/mapdev/v.in.shape/lines.c
Fix bug (xtmp/ytmp confusion)
src/mapdev/v.in.shape/vmap_import.c
src/mapdev/v.mkquads/ask_for.c
Remove local atof() prototype
src/mapdev/v.mkquads/calc_quads.c
Include <stdlib.h>
src/mapdev/v.out.e00/v.out.e00.c
src/mapdev/v.timestamp/main.c
Check return value from G_scan_timestamp()
src/mapdev/v.to.db/parse.c
Fix gisprompt string
src/misc/m.in.e00/info.c
src/misc/m.kappa/cmd/main.c
Change exit(-1) -> exit(1)
src/misc/m.kappa/cmd/prt_hdr.c
Use G_fatal_error()
src/misc/m.kappa/cmd/readin_data.c
Change exit() -> exit(1)
src/ps.map/devices/ps.devices/a3
src/ps.map/devices/ps.devices/a4
Fix paper sizes
src/ps.map/ps.map/cmd/do_labels.c
Default font size to 10pt instead of 0pt
src/ps.map/ps.map/cmd/ps_fclrtbl.c
Trap empty range
Remove debug output
src/ps.map/ps.map/cmd/ps_map.c
Draw grid after sites
src/ps.map/scripts/demo1.scr
src/ps.map/scripts/demo2.scr
src/ps.map/scripts/demo3.scr
src/ps.map/scripts/demo5.scr
src/ps.map/scripts/demo9.scr
Remove streams.dead, streams.spear vector maps
Add streams vector map
src/ps.map/scripts/demo8.scr
Disable header, comments sections
Disable icon attribute for bugsites
-src/raster/r.coin/cmd/cmd.c
+src/raster/r.coin/cmd/cmd_parms.c
src/raster/r.coin/cmd/Gmakefile
Rename cmd.c -> cmd_parms.c
src/raster/r.colors/cmd/local_proto.h
src/raster/r.colors/cmd/main.c
src/raster/r.colors/cmd/rules.c
Add -q (Quiet) flag
src/raster/r.cost/cmd/btree.c
Include <stdlib.h>
src/raster/r.cost/cmd/main.c
src/raster/r.cost/cmd/stash.h
Move G_parser() call
Remove dead code
src/raster/r.fill.dir/ppupdate.c
Enlarge array to allow for 1-based accesses
src/raster/r.his/cmd/main.c
Fix gisprompt strings (old -> new)
src/raster/r.in.bin/main.c
Change help text
src/raster/r.in.doq/cmd/get_newhead.c
src/raster/r.in.gdal/Gmakefile
Reorder libraries
src/raster/r.in.gdal/main.c
src/raster/r.info/inter/main.c
src/raster/r.info/inter/more_print.c
-src/raster/r.los/cmd/newsegment.c
src/raster/r.los/cmd/delete.c
src/raster/r.los/cmd/main.c
src/raster/r.los/cmd/mark_pts.c
src/raster/r.los/cmd/pts_elim.c
CELL -> FCELL
Remove newsegment.c
src/raster/r.mapcalc3/evaluate.c
Only display percentages on tty
src/raster/r.mapcalc3/expression.c
Fix segfault
-src/raster/r.patch/cmd/patch.c
src/raster/r.patch/cmd/Gmakefile
Remove patch.c
src/raster/r.patch/cmd/main.c
Use G_fatal_error()
src/raster/r.patch/cmd/nfiles.h
Add comment regarding MAXFILES
src/raster/r.profile/cmd/main.c
Remove unused variables
Change help text
Add return statements
src/raster/r.quant/main.c
Fix help text
src/raster/r.reclass/cmd/reclass.c
Fix reclass-of-reclass
-src/raster/r.statistics/cmd/median.c
-src/raster/r.statistics/cmd/moment.c
-src/raster/r.statistics/cmd/skew.c
src/raster/r.statistics/cmd/method.h
Remove median, moment, skew
-src/raster/r.thin/cmd/size.c
Remove size.c
src/raster/r.tiff/r.out.tiff.c
Fix help text (Pallete -> Palette)
src/raster/r.timestamp/main.c
src/raster/r.topmodel/main.c
Fix author's email address
Remove $Log$
Change help text
src/raster/r.transect/cmd/main.c
Disable width=, result= options
src/raster/wildfire/src/r.ros/spot_dist.c
Newline in string literal
-src/raster/wildfire/src/r.spread/prob_invsqr.c
+src/raster/wildfire/src/r.spread/local_proto.h
src/raster/wildfire/src/r.spread/cell_ptrHa.h
src/raster/wildfire/src/r.spread/cmd_line.h
src/raster/wildfire/src/r.spread/collect_ori.c
src/raster/wildfire/src/r.spread/costHa.h
src/raster/wildfire/src/r.spread/deleteHa.c
src/raster/wildfire/src/r.spread/display.c
src/raster/wildfire/src/r.spread/fixHa.c
src/raster/wildfire/src/r.spread/get_minHa.c
src/raster/wildfire/src/r.spread/insert2Ha.c
src/raster/wildfire/src/r.spread/insertHa.c
src/raster/wildfire/src/r.spread/main.c
src/raster/wildfire/src/r.spread/pick_dist.c
src/raster/wildfire/src/r.spread/pick_ignite.c
src/raster/wildfire/src/r.spread/ram2out.c
src/raster/wildfire/src/r.spread/replaceHa.c
src/raster/wildfire/src/r.spread/select_linksB.c
src/raster/wildfire/src/r.spread/spot.c
src/raster/wildfire/src/r.spread/spread.c
[Tidying]
Protect headers against repeated inclusion
Move definitions from header files to source files
Use ANSI prototypes
Add local_proto.h
Remove prob_invsqr.c
src/scripts/contrib/d.rast.labels/d.rast.labels
Don't trap SIGKILL
src/scripts/contrib/d.rast.leg/d.rast.leg
src/scripts/contrib/grassmirrorsmap/grass.sites.main
src/scripts/contrib/grassmirrorsmap/grass.sites.mirror
src/scripts/contrib/grassmirrorsmap/grass_sites.gif
src/scripts/contrib/grassmirrorsmap/grass_sites.htmlmap
src/scripts/contrib/grassmirrorsmap/grassmap.html
src/scripts/contrib/grassmirrorsmap/mkgrassmap.sh
Changes regarding Spain, Argentina, Belgium
index2.html -> index.html
src/scripts/contrib/r.fillnulls/r.fillnulls
src/scripts/contrib/r.to.pg/r.to.pg
src/scripts/contrib/s.in.atkisdgm/s.in.atkisdgm
src/scripts/contrib/s.in.atkisdgm/s.in.atkisktb
src/scripts/contrib/s.in.garmin.sh/s.in.garmin.sh
src/scripts/contrib/v.cutregion.sh/v.cutregion.sh
src/scripts/contrib/v.in.garmin.sh/v.in.garmin.sh
src/scripts/contrib/v.in.mapgen.sh/v.in.mapgen.sh
src/scripts/contrib/v.region.sh/v.region.sh
Don't trap SIGKILL
src/scripts/contrib/v.line2area/v.area2line
src/scripts/contrib/v.line2area/v.line2area
Use -eq instead of = (why?)
src/scripts/shells/shade.clr.sh
src/scripts/shells/shade.rel.sh
Support scale factors for lat/lon
Fix null handling
src/scripts/shells/slide.show.sh
Don't trap SIGKILL
src/sites/s.cellstats/main.c
src/sites/s.cellstats/univar.c
src/sites/s.cellstats/univar.h
Include <string.h>
Add sum operation
src/sites/s.in.ascii/get_site.c
Include attribute text in error messages
src/sites/s.in.ascii/main.c
Fix help text
Check for empty fs= value
Use G_fatal_error()
src/sites/s.in.dbf/dump.c
Enlarge buffer
src/sites/s.in.dbf/main.c
Fix help text
src/sites/s.out.ascii/main.c
Free result of G_site_format() (fix memory leak)
src/sites/s.out.e00/s.out.e00.c
Allow use of qualified map names
src/sites/s.qcount/main.c
src/sites/s.qcount/tutorial/output
src/sites/s.windavg/main.c
sites_list -> site_lists
src/tcltkgrass/main/gis_set.tcl
I18N
*** BOGUS ***
Add bordercolor=, -b, -g
Change help text
src/tcltkgrass/module/r.transect
Remove width=, result=
tools/diff.sh
Change *-{1,2} -> *-{rel,exp}
