[GRASS5] Solaris, GRASS 5.1, and Proj
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Sep 12 05:18:34 EDT 2003
On Thu, 11 Sep 2003, Markus Neteler wrote:
> But ./configure should stop with an error when
> --without_proj
> is used. Then the situation were clear.
I have fixed this now---moved the PROJ test earlier in the sequence and
disabled --with-proj / --without-proj (the test is mandatory).
--with-proj-includes and --with-proj-libs still work if required.
Paul
