[GRASS5] Tcl8.4 support?
Glynn Clements
glynn.clements at virgin.net
Sun Sep 14 11:42:03 EDT 2003
Hamish wrote:
> old business:
In my previous message, I hadn't noticed that you continued after the
signature.
> Where do you change the Makefiles to have GRASS compile with "gcc-2.95"
> instead of"gcc" (ie gcc-3.3) ?
To select a different compiler, set the CC environment variable prior
to running configure e.g.
CC=gcc-2.95 ./configure ...
Similarly for CFLAGS and LDFLAGS, e.g.
CFLAGS='-g -Wall' ./configure ...
You can also override make variables with e.g.
make CC=gcc-2.95
However, if you do this, bear in mind that the settings in head.<arch>
and config.h may not be appropriate.
> > If tcltkgrass is crashing inside "pure" Tcl/Tk code, you won't be able
> > to find out much unless you have a version of libtcl which has debug
> > info.
> I think (could be wrong) Debian binaries are stripped by default.
Most distributions strip the dynamic libraries; sometimes the -devel
package includes static libraries which aren't stripped, but mostly
you have to build your own libraries if you want debug info.
In any case, I don't think that a debugger will help with the hanging
"exec" problem.
Glynn Clements <glynn.clements at virgin.net>
