[GRASS5] Tcl8.4 support?
Hamish
hamish_nospam at yahoo.com
Mon Sep 15 03:59:44 EDT 2003
> > But back to Debian with TclTk 8.4 and the bug as reported in
> > http://article.gmane.org/gmane.comp.gis.grass.devel/1883
> > "it does freeze up (0% cpu) at the first instance of "exec"
> > in etc/nviz2.2/scripts/nviz2.2_script, line 78: (Adding panels
> > section) set panels [exec cat $index]
> > (I tried placing some exec's further up in the script & they did the
> > same lock-up)"
G: One thing which might make a difference: try adding "-lpthread" to
G: the link command. I've occasionally encountered all sorts of odd
G: behaviour with programs which are linked against libraries which are
G: linked against libpthread (typically libGL), but where the binary
G: itself isn't linked directly against libpthread.
> I'll try tcl8.4 with "-lpthread" next.
> (added to src.contrib/GMSL/NVIZ2.2/src/Gmakefile XTRA_LDFLAGS ?)
That works(!)
although I guess it really belongs somewhere else in the build system..?
or is it a bug in the debian build of the tcl8.4 libraries? (as 8.3 works ok)
thanks again,
Hamish
