[GRASS5] [5.0][PATCH]pg.in.dbf/dbfopen.c: fix weird filenames acrobatics
Bernhard Reiter bernhard at intevation.de
Mon Sep 15 05:26:31 EDT 2003
On Sun, Sep 14, 2003 at 04:54:23PM +0200, Thierry Laronde wrote:
> In dbfopen.c, the filename of the DBF file supposed to be opened was
> subject of extension changes, `strcmp' being used as if it was a
> matching function returning 0 if failed or not zero on success. And indeed
> this is almost exactly the contrary.
> Furthermore, the combination of two conditions made the first test succeeds
> in all cases, transforming every extension in ".dbf".
> Last but not least, _without renaming or copying the file_ this was this
> modified version of the filename that was given to `fopen' resulting in a
> failure in every case except when the change to ".dbf" was a null one, that
> is when the filename was already ending with ".dbf".
> The patch removes the offending stuff.
Sound reasonable,
but others have to judge this from the technical point of view.
I'm not sure how actively used the src.garden submodule actually is.
> PS0: please don't be upset by the tone of the comments: I have the very
> same with my own errors, and I make a lot of these. This is just aimed to
> be matter of fact and descriptive.
No problem at all.
As for a development list we can talk right down to the technical features.
> PS1: I'm still working on the 5.0 [5.3] branch since I have installed it
> at my work and have some job to be done without changing everything at the
> moment.
Perfectly fine.
That is what this branch is for.
> PS2: I have downloaded 5.7 and started to look at the new vector format (and
> will ask some questions/give some suggestions hopefully in the next days).
Your suggestions, questions and remarks are very welcome.
> PS3: to avoid problem, when I work on GRASS by itself, I make it during my
> spare time to be sure that I own all the copyrights of my work and can
> give/share them with the project (I'm not officially hired for doing
> programming, so during my spare time I'm sure my boss can claim strictly
> nothing). This can explain why I will make apparitions only from time to
> time).
Sounds like a good strategy to me,
happy hacking,
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030915/5c7179f2/attachment.bin
