[GRASS5] Tcl8.4 support?
Buchan Milne bgmilne at cae.co.za
Tue Sep 16 07:25:57 EDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hamish wrote:
>>>>>But back to Debian with TclTk 8.4 and the bug as reported in
>>>>>http://article.gmane.org/gmane.comp.gis.grass.devel/1883
>>>>>"it does freeze up (0% cpu) at the first instance of "exec"
>>>>>in etc/nviz2.2/scripts/nviz2.2_script, line 78:   (Adding panels
>>>>>section)    set panels [exec cat $index]
>>>>>(I tried placing some exec's further up in the script & they did
>>>>>the same lock-up)"
>>>G: One thing which might make a difference: try adding "-lpthread"
>>>to the link command. I've occasionally encountered all sorts of
>>>odd behaviour with programs which are linked against libraries
>>>which are linked against libpthread (typically libGL), but where
>>>the binary itself isn't linked directly against libpthread.
>>>> (added to src.contrib/GMSL/NVIZ2.2/src/Gmakefile  XTRA_LDFLAGS ?)
>>>That works(!)
>>Damn.
>>I have absolutely no idea how we could make configure detect this
>>situation.
>>The only easy solution is to provide a switch, e.g. --nviz-pthread,
>>which explicitly add -lpthread to the NVIZ linking switches. At least,
>>providing the switch is easy enough; dealing with user queries of the
>>form "what does this switch do and should I use it?" is likely to be
>>less straightforward.
> That' still just treating the symptom.. (although that's possibly all we
> can do from our end)
> AFAIK, this is currently only a problem with Debian/Testing. Is anybody
> running Gentoo or another bleeding edge distro who can try this? It
> would be bad for the next version of SuSE/RedHat to come out with a new
> glibc, tcl, etc & start showing this behaviour too.
Running on Mandrake cooker:
$ rpm -q glibc tcl
glibc-2.3.2-14mdk
tcl-8.4.2-1mdk
No problems with NVIZ, but I am running the NVIDIA drivers (which
replace libGL.so*). But it seems tcl/tcltk in Mandrake is built without
thread support.
Regards,
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne                Mechanical Engineer, Network Manager
Cellphone * Work            +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering         http://www.cae.co.za
GPG Key                   http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/ZvNErJK6UGDSBKcRAqB0AKCpNahDWvdmMJ9ZjQB4iSC5V2IcKQCgpTDE
5bKPvgS0/PRbfgVXL4gDt/Q=
=w6Q1
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info at cae.co.za for a copy.
