[GRASS5] Solaris GRASS 5.1, shared libraries, external PROJ
Wallace, Beverly T
beverly.t.wallace at lmco.com
Thu Sep 18 11:36:40 EDT 2003
Hi Radim,
I am running bin.$(ARCH)/grass51.
It finds the GRASS shared libraries if I move "export LD_LIBRARY_PATH"
outside of the if statement in etc/Init.sh as you suggested.
if [ ! "$LD_LIBRARY_PATH" ] ; then
LD_LIBRARY_PATH=$GISBASE/lib
else
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib
fi
For Solaris, it works OK if LD_LIBRARY_PATH starts with a colon, but
I don't know about other systems.
Thank you,
Bev
> -----Original Message-----
> From: Radim Blazek [SMTP:blazek at itc.it]
> Sent: Thursday, September 18, 2003 12:37 AM
> To: grass5 at grass.itc.it
> Subject: Re: [GRASS5] Solaris GRASS 5.1, shared libraries, external PROJ
> On Wednesday 17 September 2003 23:28, Wallace, Beverly T wrote:
> > Dear GRASS Developers,
> > I have at last successfully built GRASS 5.1 (2003_09_06) on Solaris 9.
> > Thank you to everyone who gave me advice.
> > The ps/ps.map/Makefile needs Proj includes:
> > EXTRA_INC = $(VECT_INC) $(PROJINC)
> OK, done in cvs.
> > In order to run grass51, I needed to set LD_LIBRARY_PATH to find the shared
> > libraries in dist.$ARCH/lib and the external PROJ.4 lib. This was not
> > mentioned in the INSTALL file.
> This is done in etc/Init.sh:
> else
> fi
> this section is identical to 5.0, but why it is exported only
> in the first case, would not be better
> else
> fi
> and is it necessary to test if $LD_LIBRARY_PATH is defined,
> is it ':/some/path' error?
> Maybe you are not running GRASS within regular session?
> BTW, you can run applications without $GISRC and user mapset.
> (example in GRASS++ and QGIS)
> Radim
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
