[GRASS5] src/scripts/contrib/Gmakefile bug
Hamish
hamish_nospam at yahoo.com
Mon Sep 22 06:25:08 EDT 2003
How to conditionalize the GDAL check?
H
File: [Grass] / grass / src / scripts / contrib / Gmakefile
Revision: 1.29, Fri Sep 19 10:19:41 2003 UTC (3 days ago) by markus
Branch: MAIN
CVS Tags: HEAD
Changes since 1.28: +1 -0 lines
added r.out.gdal
latest GRASS 5.3 CVS:
./configure --without-gdal
make
/usr/src/grass/grass53-CVS/src/scripts/contrib/i.spectral
make -f OBJ.i686-pc-linux-gnu/make.rules
make[1]: Entering directory `/usr/src/grass/grass53-CVS/src/scripts/contrib/i.spectral'
cp i.spectral /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
make[1]: Leaving directory `/usr/src/grass/grass53-CVS/src/scripts/contrib/i.spectral'
cp i.image.mosaic/i.image.mosaic /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp i.tasscap/i.tasscap.tm4 /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp i.tasscap/i.tasscap.tm5 /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp i.tm.dehaze/i.tm.dehaze /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp ps.add.pagesize/ps.add.pagesize /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp r.edge.dig/r.edge.dig /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp r.fillnulls/r.fillnulls /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp r.mpatch/r.mpatch /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp r.out.bil/r.out.bil /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp r.out.gdal/r.out.gdal /usr/src/grass/grass53-CVS/dist.i686-pc-linux-gnu/scripts
cp: cannot stat `r.out.gdal/r.out.gdal': No such file or directory
make: *** [all] Error 1
