> > How to conditionalize the GDAL check? > > It's just a script and doesn't need to be conditionalized. > I assume that you forgot to use '-dP' to get the > subdirectory. Possible? Very. > cd /usr/src/grass/grass53-CVS/src/scripts/contrib > cvs up -dP > > ...should solve the problem. It does. thanks, Hamish
