[GRASS5] Debugging question
Bernhard Reiter bernhard at intevation.de
Mon Sep 22 08:23:05 EDT 2003
In general: Check the hints in /grass/documents/debugging.txt
On Tue, Sep 23, 2003 at 12:02:43AM +1200, Hamish wrote:
> also in anyone can help, I'm having problems getting gdb to work with GRASS.
> I compiled with:
> CFLAGS="-O3 -march=pentium4 -Wall -ggdb" LDFLAGS="-s" ./configure ...
Good.
> but gdb can't find any debug info:
> GRASS:~ > gdb r.sun
Run the actual command in etc/bin/cmd or etc/bin/inter not the wrapper
from the grass command prompt.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030922/e924c196/attachment.bin
