[GRASS5] GRASS binaries for Mac OS X
Markus Neteler
neteler at itc.it
Mon Sep 22 09:36:17 EDT 2003
I am still strying to compile GRASS 5.7 on Mac OSX.
At time I face the general problem that, when compiling
libraries, symbols from other GRASS libs are required.
This doesn't happen on Linux.
I solved this for some libs by adding e.g.
EXTRA_LIBS=$(LIBLINK)
etc to the Makefile. Like that the compile order is important
and needs to be slightly modified. So far, so nice.
But in libgis I got stuck with
cd lib/gis
make
OBJ.powerpc-apple-darwin6.6/writ_zeros.o OBJ.powerpc-apple-darwin6.6/yes.o
OBJ.powerpc-apple-darwin6.6/zero.o OBJ.powerpc-apple-darwin6.6/zero_cell.o
OBJ.powerpc-apple-darwin6.6/zone.o OBJ.powerpc-apple-darwin6.6/G_dump.o
-lgrass_datetime -lz -o
/grass57exp/dist.powerpc-apple-darwin6.6/lib/libgrass_gis.dylib
ld: Undefined symbols:
_environ
/usr/bin/libtool: internal link edit command failed
make: *** [/grass57exp/dist.powerpc-apple-darwin6.6/lib/libgrass_gis.dylib]
Error 1
The file 'putenv.c' from GRASS 5.3 should probably have
#include <unistd.h>
added as under Linux is defined:
grep environ /usr/include/unistd.h
extern char **environ;
Unfortunately on Mac OSX there is nothing like that in
/usr/include/sys/unistd.h
nor in another place.
How to solve that?
Markus
PS: I can provide access to this Mac OSX machine.
