[GRASS5] Just a guess on "G_window_overlap"
Antonello Andrea moovida at katamail.com
Thu Sep 25 02:02:15 EDT 2003
Probably no one uses "G_window_overlap" anymore, since the new vector system
is out, but just to know:
As Darrell McCauley in 1994 said:
"Specifically, at a first glance it looks like the functions G_window_overlap
and G_window_percentage_overlap are defined in src/libes/gis/wind_overlap.c
but are not declared extern anywhere -- a bunch of vector routines
that call them can't find them.  Should they be declared in gisdefs.h?"
The file seems to be in the libgis.a, the Gmakefile has the file queued for
compilation, but when needed, the result is a:
ld: Undefined symbol    G_window_overlap
Funny, if you directly include the file wind_overlap.c in the compilation of
the shared lib, it works. So I'm fine now, i'm curious to understand what
happened with that thing.
If anyone has a hint...
Cheers
Andrea
____________________________________________________________________________
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel:  +393288497722
fax:  +390461882672
