[GRASS5] GRASS 5.3/5.7, GDAL and southern hemisphere
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Sep 25 10:03:27 EDT 2003
Hello Markus
On Thu, 25 Sep 2003, Markus Neteler wrote:
> Today we imported a LANDSAT scene into a southern
> hemisphere location (Argentina), UTM. There is a slight
> confusion with 'south: defined' and negative zone numbers:
> gdalinfo tells us:
> GRASS 5.7.0-cvs:~ > gdalinfo tuc6.tif
> Driver: GTiff/GeoTIFF
> Size is 1024, 692
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 4S",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.2572235629972,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-159],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",10000000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","32704"]]
> Origin = (-65.356600,9999973.275500)
> Pixel Size = (30.000000,-30.000000)
> Corner Coordinates:
> Upper Left ( -65.357, 9999973.275)
> Lower Left ( -65.357, 9979213.275)
> Upper Right ( 30654.643, 9999973.275)
> Lower Right ( 30654.643, 9979213.275)
> Center ( 15294.643, 9989593.275)
> Band 1 Block=1024x1 Type=Byte, ColorInterp=Gray
> Importing it:
> GRASS 5.7.0-cvs:~ > r.in.gdal in=tuc6.tif out=tuc6
> 100%
> CREATING SUPPORT FILES FOR tuc6
> SETTING GREY COLOR TABLE FOR tuc6 (8bit, full range)
> Error on display:
> GRASS 5.7.0-cvs:~ > d.rast tuc6
> WARNING: [tuc6] in mapset [tucuman] - in different zone [-4] than current
> region [4]
> WARNING: unable to open raster map [tuc6 in tucuman]
> ERROR: Not able to open cellfile for [tuc6]
Seems like maybe the location is not set up properly? Did you do it with
g.setproj or r.in.gdal. Could you try editing the DEFAULT_WIND and WIND
files manually to change the zone to -4? Does that help?
