[GRASS5] bug reports for GRASS 5.7
Scott Mitchell
smitch at mac.com
Fri Apr 2 15:23:33 EST 2004
The developer tools include the standard GNU tools, including gdb, the
debugger.
So you start the program within the debugger using
gdb program_name (which is the full path to the grass module, in this
case probably something like
/usr/local/grass57-13_02_2004/bin/g.mapsets)
which will put you in to a gdb prompt. From there, enter
run -l
to start the program with -l as the argument. When you get to the
error, it will put you back at the gdb prompt, and you can enter the
command "where" to get a traceback of where it happened in the program.
Use "quit" to get out to your shell.
Actually, you can probably skip all that, because I decided to test my
instructions before sending, and my machine generates the error too.
So keep this for future reference, and Glynn, here are the results, I
wish they meant something to me:
(gdb) run -l
Starting program: /usr/local/grass57-13_02_2004/bin/g.mapsets -l
Reading symbols for shared libraries +++.. done
Program received signal SIGTRAP, Trace/breakpoint trap.
0x8fe1a528 in __dyld__dyld_start ()
(gdb) where
#0 0x8fe1a528 in __dyld__dyld_start ()
warning: ppc_frame_chain_valid: stack pointer from 0xbffffab4 to 0x1000
grows upward; assuming invalid
#1 0x00000000 in ?? ()
On Apr 2, 2004, at 15:01, Michael Barton wrote:
> On Friday, April 2, 2004, at 12:54 PM, Glynn Clements wrote:
>> Can you run "g.mapsets -l" under a debugger and get a backtrace?
> Probably.
> I'm copying this to Scott Mitchell who may have a suggestion along
> these lines. I have all the Apple developer tools installed. So this
> means that I certainly have access to debugging tools. I simply don't
> know what they are. If you know of any generic ones for BSD Unix
> and/or tcshell, I will give them a try.
> Michael
> ______________________________
> Michael Barton, Professor & Curator
> Department of Anthropology
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing: Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell at carleton.ca
