[GRASS5] bug reports for GRASS 5.7
Scott Mitchell smitch at mac.com
Fri Apr 2 18:16:25 EST 2004
On Friday, Apr 2, 2004, at 17:53 Canada/Eastern, Glynn Clements wrote:
> Scott Mitchell wrote:
>> So you start the program within the debugger using
> The actual program would be in etc/bin/cmd, e.g.
> 	/usr/local/grass57-13_02_2004/etc/bin/cmd/g.mapsets
> Almost everything in the bin directory is a hard link to
> etc/front.end.
Oof, I knew I was forgetting something...
>> (gdb) run -l
>> Starting program: /usr/local/grass57-13_02_2004/bin/g.mapsets -l
>> Reading symbols for shared libraries +++.. done
>> Program received signal SIGTRAP, Trace/breakpoint trap.
>> 0x8fe1a528 in __dyld__dyld_start ()
> This is a red herring; can you continue until you get the actual
> SIGBUS signal?
Aha !  Now this is more useful, even I can see that:
(gdb) run -l
Starting program: /usr/local/grass57-13_02_2004/etc/bin/cmd/g.mapsets -l
Reading symbols for shared libraries +++++.. done
Program received signal EXC_BAD_ACCESS, Could not access memory.
0x90006f40 in strlen ()
(gdb) where
#0  0x90006f40 in strlen ()
#1  0x0022f100 in G_store (s=0x0) at store.c:16
#2  0x0000280c in get_available_mapsets () at get_maps.c:14
#3  0x00001ff4 in main (argc=2, argv=0xbffffa3c) at main_cmd.c:68
Scott W. Mitchell		Scott_Mitchell at carleton.ca
Department of Geography and Environmental Studies
Carleton University, B349 Loeb Building
Ottawa, ON Canada
+1-613-520-2600 ext 2695
