[GRASS5] [bug #2380] (grass) unexpected '(' in r.univar
Markus Neteler neteler at itc.it
Tue Apr 13 07:37:09 EDT 2004
On Tue, Apr 13, 2004 at 10:50:29AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2380
> Subject: unexpected '(' in r.univar
> Platform: WindowsNT/2000/XP
> grass obtained from: Mirror of Trento site
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.0.3 (Oktober 2003)
> while executing r.univar (v.1.7.2.2 2002/10/23) the errormessage "unexpected '(' in line 18" appears.
> after changing the line "function cleanup()" to "cleanup()" [the same in line 24] r.univar runs without problems. Is it a bug or a cygwin-problem?
The bug is related to the usage of the word "function".
Please try to remove it, keep only "cleanup()" in that line.
Then it should work. This is already fixed in >= 5.3.
Markus
