[GRASS5] g.parser with multiple=YES ?
Glynn Clements glynn.clements at virgin.net
Thu Apr 15 13:04:06 EDT 2004
Hamish wrote:
> I was just wondering how to use "option->multiple=YES;" in a bash script
> using g.parser? There seems to be something in the code, but no examples
> anywhere that I could find.
Although you can set the multiple flag, the answers field is ignored.
I presume that you can still split the $GIS_OPT_* value (taken from
the answer field) into its components manually.
Glynn Clements <glynn.clements at virgin.net>
