[GRASS5] a shy question about nullvalue
    Andrea Antonello
    moovida at katamail.com
    Sun Apr 18 04:51:00 EDT 2004
Hy folks,
When a raster map is created, the range is written to file in cell_misc.
Since that is given from the start, why using the second map defining the
null-values instead of simply defining a null-value outside of that range for
every map?
With the growing size of files nowadays I think reading the file twice (normal
+ nullplaceholder) and then compare them could get a long job.
Let's not argue about who should implement this :) For now it's just a easy
question and couriosity.
Cheers
Andrea
____________________________________________________________________________
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel:  +393288497722
fax:  +390461882672
