[GRASS5] tcltkgrass readme text (not)
Michael Barton
michael.barton at asu.edu
Tue Apr 20 11:53:00 EDT 2004
Well...
I **thought** I did select plain ASCII. When I have a bit of time later
this week or next I'll try to figure this out and post a new package to
my web site.
Also, I'm part way into a tcltkgrass 4.1 that streamlines access to
scripts and will use the same scripts for GRASS 5.3 and 5.7. I've been
swamped with other things, but should get some time soon to move ahead
on this.
What is the non-ASCII character in help.tcl. I don't remember messing
with help (though my memory is not always to be trusted), but can fix
this.
Michael Barton
On Tuesday, April 20, 2004, at 03:01 AM, grass5-request at grass.itc.it
wrote:
> Doesn't the text editor have an option to select the output encoding?
> Text should be in ASCII where possible, otherwise either ISO-8859-1 or
> UTF-8 (I'm not sure which we should prefer although, AFAICT, all
> existing occurrences of non-ASCII characters are in ISO-8859-1).
> BTW, tcltkgrass/main/help.tcl contains a non-ASCII character:
> Using the select button, you can choose the specific module´s
> manpage.
> That should probably be changed to the normal ASCII single quote
> character.
> Glynn Clements <glynn.clements at virgin.net>
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
