[GRASS5] [5.7] d.vect bug in lat/lon when crossing 180 deg
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Aug 23 04:18:22 EDT 2004
On Mon, 23 Aug 2004, Hamish wrote:
> Hi,
> I'm trying to fix d.vect for use with lat/lon when the region traverses
> 180 degrees (centering the view on the pacific).
> e.g. g.region w=0 e=360
> d.vect includes code to only draw stuff which is actually on screen;
> I've just patched the code to get all areas to show up[*], but am
> stumbling on getting point data to work in a clean way.
Just off the top of my head this sounds like a job for G_adjust_easting()?
Only that I remember Eric Miller fixing d.sites using this function.
Paul
