[GRASS5] PNG driver problem
Glynn Clements
glynn.clements at virgin.net
Wed Aug 25 16:12:06 EDT 2004
David Piasecki wrote:
> I looked around last night and couldn't seem to find the version of the
> PNG driver you mentioned. I downloaded the latest 5.3 CVS snapshot, and
> the documentation for the PNG driver did not mention any option for
> writing to a file other than calling d.mon stop=PNG. Is the
> documentation incorrect, or am I looking in the wrong place? Should I
> be looking for the latest CVS snapshot of 5.7? I tried, but I wasn't
> able to find it, though I'm still somewhat new to CVS. It often feels
> like a guessing game when trying to figure out what's available.
The change was made within the last week (2004/08/19 21:04:08 for the
5.3 source code; the manual page and 5.7 were updated on the 20th). If
you obtained the code directly from CVS, it should be present. If you
downloaded a CVS snapshot tar file, it may or may not be present,
depending upon the date of the snapshot; the 2004_08_21 snapshots
(both 5.3 and 5.7) should include it.
The file "pngdriver" manual page (generated from the file
html/html/pngdriver.html) should say:
Environment variables
Several environment variables effect the operation of the
PNG driver.
[snip]
GRASS_PNG_AUTO_WRITE=[TRUE|FALSE]
if set to "TRUE", the image file will be
written after each operation (i.e. whenever
a client disconnects), rather than only
being written out when the driver termi
nates.
Glynn Clements <glynn.clements at virgin.net>
