[GRASS5] PNG driver problem
David Piasecki piasecda at nv.doe.gov
Wed Aug 25 16:46:05 EDT 2004
Or perhaps the quickest solution is to simply change the environment
variable to TRUE just before a display command. However, I see that
Client.c simply has a write_image() call on ClientClose() if the
AUTO_WRITE environment variable had been set. Is it that simple to
create a new binary, something like d.write_png? It could simply call
write_image().
David
On Aug 25, 2004, at 1:12 PM, Glynn Clements wrote:
> David Piasecki wrote:
>> I looked around last night and couldn't seem to find the version of
>> the
>> PNG driver you mentioned. I downloaded the latest 5.3 CVS snapshot,
>> and
>> the documentation for the PNG driver did not mention any option for
>> writing to a file other than calling d.mon stop=PNG. Is the
>> documentation incorrect, or am I looking in the wrong place? Should I
>> be looking for the latest CVS snapshot of 5.7? I tried, but I wasn't
>> able to find it, though I'm still somewhat new to CVS. It often feels
>> like a guessing game when trying to figure out what's available.
> The change was made within the last week (2004/08/19 21:04:08 for the
> 5.3 source code; the manual page and 5.7 were updated on the 20th). If
> you obtained the code directly from CVS, it should be present. If you
> downloaded a CVS snapshot tar file, it may or may not be present,
> depending upon the date of the snapshot; the 2004_08_21 snapshots
> (both 5.3 and 5.7) should include it.
> The file "pngdriver" manual page (generated from the file
> html/html/pngdriver.html) should say:
>    Environment variables
>        Several environment variables effect the operation of  the
>        PNG driver.
> [snip]
>                      GRASS_PNG_AUTO_WRITE=[TRUE|FALSE]
>                      if set to "TRUE", the  image  file  will  be
>                      written  after each operation (i.e. whenever
>                      a  client  disconnects),  rather  than  only
>                      being  written  out  when  the driver termi­
>                      nates.
> Glynn Clements <glynn.clements at virgin.net>
