[GRASS5] Re: max res. PPM image dump from NVIZ
Thu Aug 26 02:11:19 EDT 2004
[max res. PPM image dump from NVIZ]
+: Output now looks great. Image saved ok.
-: After the image dump, it would render the hi-res polygon ok, but the
low res movement 'Grid' has disappeared, then after a few seconds of
playing with that:
Final Assembled Image will be 2048 x 1995
Writing Tile 1 of 4
Writing Tile 2 of 4
Writing Tile 3 of 4
Writing Tile 4 of 4
Assembling Tiles
Destroy Pixmap and GLXPixmap
global-exag = 3.000000
recalculating normals...
100
200
300
100
200
X Error of failed request:  GLXBadContextTag
  Major opcode of failed request:  144 (GLX)
  Minor opcode of failed request:  1 (X_GLXRender)
  Serial number of failed request:  3736
  Current serial number in output stream:  3737
child process exited abnormally
    while executing
"exec
/usr/local/src/grass/grass57/dist.i686-pc-linux-gnu/etc/nviz2.2/NVWISH2
.2 -f
/usr/local/src/grass/grass57/dist.i686-pc-linux-gnu/etc/nviz2.2/scri..."
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
>&@stdout"
Hamish
