[GRASS5] Re: max res. PPM image dump from NVIZ
Glynn Clements glynn.clements at virgin.net
Sat Aug 28 16:55:16 EDT 2004
Glynn Clements wrote:
> > > > X Error of failed request:  GLXBadContextTag
> > > >   Major opcode of failed request:  144 (GLX)
> > > >   Minor opcode of failed request:  1 (X_GLXRender)
> > > >   Serial number of failed request:  3736
> > > >   Current serial number in output stream:  3737
> > > I can't reproduce this with 5.3, and I don't have an up-to-date 5.7
> > > built right now. Can you see if it happens for you with 5.3?
> > Happens both with the latest 5.3 and 5.7.
> > Just after it finishes writting the PPM, the low-res 'grid' is drawn,
> > but the southern 10-15% is missing. When you change the view angle you
> > are looking at a blank screen, when you finish it redraws the hi-res
> > 'polygon' version ok.
> > -> Resizing the viewing window causes the above error (& crash).
> I can't reproduce this.
> However try moving the Destroy_OS_Ctx() call in do_zoom.c to *before*
> the point where it tries to redraw everything, i.e.:
> #if defined(HAVE_PBUFFERS) || defined(HAVE_PIXMAPS)
>     Destroy_OS_Ctx();
> #endif
> /* Done */
> /* Reset viewport and draw orinanl view */
>     GS_set_viewport(a_orig, c_orig, b_orig, d_orig);
>     Ndraw_all_cmd(data, interp, argc, argv);
Duh. No, that won't work; the "makecurrent" operation has to occur
first.
Essentially, those lines need to be removed, and an Ndraw_all added to
the Tcl code after the makecurrent operation.
Glynn Clements <glynn.clements at virgin.net>
