[GRASS5] r.average/r.stats bug
Markus Neteler neteler at itc.it
Wed Dec 1 05:11:20 EST 2004
to my surprise I found r.average to be non-functional
with certain combinations of INT/FP maps:
Using Spearfish5.7 sample data:
GRASS 5.7.cvs:~ > r.stats -anC fields,elevation.10m
Segmentation fault
GRASS 5.7.cvs:~ > r.average base=fields cover=elevation.10m out=field.avgelev
r.average: ERROR running r.stats command
Segmentation fault
GRASS 5.7.cvs:~ > r.info -t fields
datatype=CELL
GRASS 5.7.cvs:~ > r.info -t elevation.10m
datatype=DCELL
The problem is the -C flag for r.stats as used in r.average (and related
commands).
I found that the 'for' loop in r.stats/main.c tries to open a third
map which isn't there. At least the debugger stops in that row.
Not sure how to fix it, the loop is slightly different in r.patch which
also accepts more than one input map.
Assistance appreciated,
 Markus
